Ga door naar hoofdinhoud
Lenovo Ideapad 320-15ABR Screen Replacement
Wat je nodig hebt
  1. Lenovo Ideapad 320-15ABR Screen Replacement, Screen: stap 1, afbeelding 1 van 3 Lenovo Ideapad 320-15ABR Screen Replacement, Screen: stap 1, afbeelding 2 van 3 Lenovo Ideapad 320-15ABR Screen Replacement, Screen: stap 1, afbeelding 3 van 3
    • Begin by prying off the black cover surrounding the screen by wedging the the iFixit opening tool underneath it. Work your way down until you reach the hinge cover.
    • Insert iFixit opening tool in to the hinge cover as pictured and begin slowly prying it off.
    • This will require some force, but take care not to break the hinge cover.
    • Remove the black cover.
  2. Lenovo Ideapad 320-15ABR Screen Replacement: stap 2, afbeelding 1 van 3 Lenovo Ideapad 320-15ABR Screen Replacement: stap 2, afbeelding 2 van 3 Lenovo Ideapad 320-15ABR Screen Replacement: stap 2, afbeelding 3 van 3
    • Using the Phillips #1 screwdriver, remove the four 3mm screws securing the screen, and put them on the magnetic mat so you will not misplace them.
    • Gently lift the screen out and place it facing down on the keyboard.
  3. Lenovo Ideapad 320-15ABR Screen Replacement: stap 3, afbeelding 1 van 3 Lenovo Ideapad 320-15ABR Screen Replacement: stap 3, afbeelding 2 van 3 Lenovo Ideapad 320-15ABR Screen Replacement: stap 3, afbeelding 3 van 3
    • Carefully flip the hinge securing the connector up with the opening tool.
    • Slowly work the plug out of the connector.
    • Do not pull by the the cable, as the cable is fragile.
    • Insert the plug from the replacement screen in to the connector. Make sure the connection is secure before flipping the hinge back down.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Één opmerking
How to replace hinge for this model
Deepak Singh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 4,577
