Ga door naar hoofdinhoud
Lenovo Ideapad 320-15ABR Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo Ideapad 320-15ABR Hard Drive Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 2, afbeelding 1 van 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 2, afbeelding 2 van 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 3, afbeelding 1 van 2 Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 4, afbeelding 1 van 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 4, afbeelding 2 van 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 5, afbeelding 1 van 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 5, afbeelding 2 van 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Hard Drive Replacement, Hard Drive: stap 6, afbeelding 1 van 2 Lenovo Ideapad 320-15ABR Hard Drive Replacement, Hard Drive: stap 6, afbeelding 2 van 2
    • Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Gently lift up the hard disk from the left.
  7. Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 7, afbeelding 1 van 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 7, afbeelding 2 van 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 7, afbeelding 3 van 3
    • Do not lift hard drive straight up as it risks breaking the connection port.
    • Carefully pull the hard drive away and out of the connection port.
  8. Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 8, afbeelding 1 van 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 8, afbeelding 2 van 3 Lenovo Ideapad 320-15ABR Hard Drive Replacement: stap 8, afbeelding 3 van 3
    • Detach the bracket from the hard drive by pulling the bracket edges apart.
Conclusie
25 andere personen hebben deze handleiding voltooid.
Anurag Deb
1.048 Reputatie
3 handleidingen geschreven
4 opmerkingen
What is the maximum thickness of the replacement Hard Drive/SSD.
Drew Howden - Antwoord
It takes a standard 2.5” laptop HDD/SSD. They do not vary in thickness.
TheSolderSnake -
@TheSolderSnake You might want to use google to see the variation in 2.5” laptop drive thickness before making such a confident statement. ;)
Ben - Antwoord
This is gonna be fun! lol. I’ll be doing this in 5-15 minutes. Wish me luck!!!
Paul Hucik Jr - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 172
Altijd: 24,155
