Ga door naar hoofdinhoud
Lenovo Ideapad 320-15ABR Fan Replacement
Wat je nodig hebt
  1. Lenovo Ideapad 320-15ABR Fan Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Fan Replacement: stap 2, afbeelding 1 van 3 Lenovo Ideapad 320-15ABR Fan Replacement: stap 2, afbeelding 2 van 3 Lenovo Ideapad 320-15ABR Fan Replacement: stap 2, afbeelding 3 van 3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Fan Replacement: stap 3, afbeelding 1 van 2 Lenovo Ideapad 320-15ABR Fan Replacement: stap 3, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Fan Replacement: stap 4, afbeelding 1 van 3 Lenovo Ideapad 320-15ABR Fan Replacement: stap 4, afbeelding 2 van 3 Lenovo Ideapad 320-15ABR Fan Replacement: stap 4, afbeelding 3 van 3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Fan Replacement: stap 5, afbeelding 1 van 3 Lenovo Ideapad 320-15ABR Fan Replacement: stap 5, afbeelding 2 van 3 Lenovo Ideapad 320-15ABR Fan Replacement: stap 5, afbeelding 3 van 3
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Fan Replacement, Battery: stap 6, afbeelding 1 van 1
    • Remove the four 6mm screws using the Phillips #1 screwdriver.
  7. Lenovo Ideapad 320-15ABR Fan Replacement: stap 7, afbeelding 1 van 2 Lenovo Ideapad 320-15ABR Fan Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
  8. Lenovo Ideapad 320-15ABR Fan Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery.
  9. Lenovo Ideapad 320-15ABR Fan Replacement, Fan: stap 9, afbeelding 1 van 2 Lenovo Ideapad 320-15ABR Fan Replacement, Fan: stap 9, afbeelding 2 van 2
    • Disconnect black and grey wires by simply giving them a light tug.
  10. Lenovo Ideapad 320-15ABR Fan Replacement: stap 10, afbeelding 1 van 1
    • Remove the 6mm Phillips #1 screw connecting the fan to the laptop.
  11. Lenovo Ideapad 320-15ABR Fan Replacement: stap 11, afbeelding 1 van 3 Lenovo Ideapad 320-15ABR Fan Replacement: stap 11, afbeelding 2 van 3 Lenovo Ideapad 320-15ABR Fan Replacement: stap 11, afbeelding 3 van 3
    • Lift the fan slightly and straight upward and unwind the black and grey wires from the fan.
  12. Lenovo Ideapad 320-15ABR Fan Replacement: stap 12, afbeelding 1 van 1
    • Identify the red, black, yellow, and brown wire coming from the back of the fan connecting to the motherboard with a white connector piece.
  13. Lenovo Ideapad 320-15ABR Fan Replacement: stap 13, afbeelding 1 van 2 Lenovo Ideapad 320-15ABR Fan Replacement: stap 13, afbeelding 2 van 2
    • Slowly pull and wiggle the white connector piece until it comes loose from the laptop.
  14. Lenovo Ideapad 320-15ABR Fan Replacement: stap 14, afbeelding 1 van 1
    • Replace the new fan.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 42
Altijd: 5,170
