Inleiding
This laptop allows you to use any 2.5” Hard Drive (HDD) or Solid State Drive (SSD) with a SATA3 connection.
Wat je nodig hebt
Flip the computer.
Using a Phillips screwdriver, remove the screw that has an icon like the one in the picture.
Slide the unit out from the side, until it is completely out.
Put it aside.
Unscrew the remaining 12 screws. Make sure you keep them in order.
Using a plastic spudger, loosen the clips located under the disk drive.
Keep on doing this down the edge, until the base starts to come loose.
Remove the casing and set it aside.
Locate the disk drive.
Using the spudger, loosen the pin holding the disk drive in place.
Remove the existing unit pulling gently and diagonally, as seen in the picture.
Now, reassemble the laptop by following steps 1, 2, 3 and 4 in reverse and Congrats! You just installed your new hard drive.
Remember: you will have to reinstall any Operating System to make use of your laptop. Have an USB Thumb drive with a Windows, Linux or any other OS of your choice at hand.
3 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
