Inleiding
This guide will give you a step by step process on how to replace a daughterboard for a Lenovo IdeaPad 120s-14IAP, including the USB headphone jack, micro SD card reader and NOVO button.
Wat je nodig hebt
Orient the laptop so the top is laying flat on your work surface.
Remove ten 1.5mm Torx T5 screws from the back of the laptop.
Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
Bijna klaar!
Conclusie
