Ga door naar hoofdinhoud
Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement
Wat je nodig hebt
  1. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement: stap 2, afbeelding 1 van 1
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement, USB Daughterboard: stap 3, afbeelding 1 van 2 Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement, USB Daughterboard: stap 3, afbeelding 2 van 2
    • Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
  4. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, disconnect the speaker on the left from the USB daugterboard.
    • Remove two 2.5 mm Phillips #0 screws from the daughterboard.
    • Remove the daughterboard from the laptop.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 778
