Ga door naar hoofdinhoud
Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement
Wat je nodig hebt
  1. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: stap 2, afbeelding 1 van 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: stap 2, afbeelding 2 van 2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: stap 3, afbeelding 1 van 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: stap 4, afbeelding 1 van 1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: stap 5, afbeelding 1 van 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: stap 5, afbeelding 2 van 2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement, Wi-Fi Card: stap 6, afbeelding 1 van 1
    • Locate the Wi-Fi card.
  7. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the two wires that are connected to the Wi-Fi card by gently pulling them up.
  8. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: stap 8, afbeelding 1 van 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: stap 8, afbeelding 2 van 2
    • Unscrew the one 4mm screw keeping the card in place.
  9. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: stap 9, afbeelding 1 van 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: stap 9, afbeelding 2 van 2
    • Gently pull the Wi-Fi card out of place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alex Daughters
405 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 1,239
