Ga door naar hoofdinhoud
Lenovo IdeaTab S2109A-F Speaker Replacement
Wat je nodig hebt
  1. Lenovo IdeaTab S2109A-F Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Lenovo IdeaTab S2109A-F Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Speaker Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaTab S2109A-F Speaker Replacement: stap 2, afbeelding 2 van 2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Speaker Replacement: stap 3, afbeelding 1 van 1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F Speaker Replacement, Speaker: stap 4, afbeelding 1 van 2 Lenovo IdeaTab S2109A-F Speaker Replacement, Speaker: stap 4, afbeelding 2 van 2
    • Remove the ten 2 mm black screws from the edges of the system board with a Phillips #00 screwdriver.
  5. Lenovo IdeaTab S2109A-F Speaker Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the gold connector by lifting the latch with the plastic opening tool.
  6. Lenovo IdeaTab S2109A-F Speaker Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaTab S2109A-F Speaker Replacement: stap 6, afbeelding 2 van 2
    • Pull up on the L-shaped board.
    • The bottom and top connection points should disconnect.
  7. Lenovo IdeaTab S2109A-F Speaker Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaTab S2109A-F Speaker Replacement: stap 7, afbeelding 2 van 2
    • Remove the seven 2 mm black screws connecting the speakers using the Phillips #00 screwdriver.
  8. Lenovo IdeaTab S2109A-F Speaker Replacement: stap 8, afbeelding 1 van 3 Lenovo IdeaTab S2109A-F Speaker Replacement: stap 8, afbeelding 2 van 3 Lenovo IdeaTab S2109A-F Speaker Replacement: stap 8, afbeelding 3 van 3
    • Lift the disconnected speakers from their resting position.
    • Grab the red and black cable with your index finger and thumb.
  9. Lenovo IdeaTab S2109A-F Speaker Replacement: stap 9, afbeelding 1 van 1
    • Pull up on the connection to disconnect the speakers.
Conclusie
Caelen
228 Reputatie
2 handleidingen geschreven
USF Tampa, Team 17-3, Watkins Winter 2015 Lid van USF Tampa, Team 17-3, Watkins Winter 2015
USFT-WATKINS-W15S17G3
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 461
