Ga door naar hoofdinhoud
Lenovo IdeaTab S2109A-F Camera Replacement
Wat je nodig hebt
  1. Lenovo IdeaTab S2109A-F Camera Replacement, Battery: stap 1, afbeelding 1 van 2 Lenovo IdeaTab S2109A-F Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Camera Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaTab S2109A-F Camera Replacement: stap 2, afbeelding 2 van 2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Camera Replacement: stap 3, afbeelding 1 van 1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F Camera Replacement, Removing the Camera Housing: stap 4, afbeelding 1 van 3 Lenovo IdeaTab S2109A-F Camera Replacement, Removing the Camera Housing: stap 4, afbeelding 2 van 3 Lenovo IdeaTab S2109A-F Camera Replacement, Removing the Camera Housing: stap 4, afbeelding 3 van 3
    • Remove the two 4 mm screws from the right side of the housing with the Phillips #00 screwdriver.
  5. Lenovo IdeaTab S2109A-F Camera Replacement, Unscrewing the system board: stap 5, afbeelding 1 van 2 Lenovo IdeaTab S2109A-F Camera Replacement, Unscrewing the system board: stap 5, afbeelding 2 van 2
    • Locate the long, L-shaped system board.
    • Copper runs most of this length.
    • Remove the ten 2 mm screws securing the system board with a Phillips #00 screwdriver.
  6. Lenovo IdeaTab S2109A-F Camera Replacement, Disconnecting the system board: stap 6, afbeelding 1 van 1
    • Flip the central latch with a large opening tool to expose a gold connector.
    • Gently pull the gold connector using the latch.
  7. Lenovo IdeaTab S2109A-F Camera Replacement, Moving the System board: stap 7, afbeelding 1 van 2 Lenovo IdeaTab S2109A-F Camera Replacement, Moving the System board: stap 7, afbeelding 2 van 2
    • Pull up the L-shaped board to disconnect the two connectors at the top and bottom of the board.
  8. Lenovo IdeaTab S2109A-F Camera Replacement, Disconnecting the camera: stap 8, afbeelding 1 van 2 Lenovo IdeaTab S2109A-F Camera Replacement, Disconnecting the camera: stap 8, afbeelding 2 van 2
    • Grab the camera connection with your index finger thumb.
    • Disconnect the camera by gently pulling on this wire.
Conclusie
To reassemble this device, follow these instructions in reverse order.
Timothy
301 Reputatie
3 handleidingen geschreven
USF Tampa, Team 17-3, Watkins Winter 2015 Lid van USF Tampa, Team 17-3, Watkins Winter 2015
USFT-WATKINS-W15S17G3
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 321
