Ga door naar hoofdinhoud
Lenovo IdeaTab S2109A-F Battery Replacement
Wat je nodig hebt
  1. Lenovo IdeaTab S2109A-F Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Lenovo IdeaTab S2109A-F Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaTab S2109A-F Battery Replacement: stap 2, afbeelding 2 van 2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Battery Replacement: stap 3, afbeelding 1 van 1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Caelen
228 Reputatie
2 handleidingen geschreven
USF Tampa, Team 17-3, Watkins Winter 2015 Lid van USF Tampa, Team 17-3, Watkins Winter 2015
USFT-WATKINS-W15S17G3
4 Leden
10 handleidingen geschreven
2 opmerkingen
Folks this is not easy! The first thing that happened, my screen broke. Then it took about thirty minutes to finally get the back off and the on-off swithch was damaged. Take it to a shop and let them do the damage, then its up to them to pay for it or replace it. I’m now out a s2109 Lenovo tablet because the instructions said easy. Maybe his was. This one sure as heck was not!!
jangoodman - Antwoord
Theres some screws missing from the directions, under the speakers and in a hole along one side. Tiny torx on the side.
Devin Holland - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 1,564
