Ga door naar hoofdinhoud
Lenovo IdeaTab A2109 System Board Replacement
Wat je nodig hebt
  1. Lenovo IdeaTab A2109 System Board Replacement, Battery: stap 1, afbeelding 1 van 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 System Board Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaTab A2109 System Board Replacement: stap 2, afbeelding 2 van 2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 System Board Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaTab A2109 System Board Replacement: stap 3, afbeelding 2 van 2
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 System Board Replacement: stap 4, afbeelding 1 van 2 Lenovo IdeaTab A2109 System Board Replacement: stap 4, afbeelding 2 van 2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 System Board Replacement: stap 5, afbeelding 1 van 2 Lenovo IdeaTab A2109 System Board Replacement: stap 5, afbeelding 2 van 2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
  6. Lenovo IdeaTab A2109 System Board Replacement, System Board: stap 6, afbeelding 1 van 3 Lenovo IdeaTab A2109 System Board Replacement, System Board: stap 6, afbeelding 2 van 3 Lenovo IdeaTab A2109 System Board Replacement, System Board: stap 6, afbeelding 3 van 3
    • Remove three silver 1.8 mm Phillips #00 screws.
  7. Lenovo IdeaTab A2109 System Board Replacement: stap 7, afbeelding 1 van 3 Lenovo IdeaTab A2109 System Board Replacement: stap 7, afbeelding 2 van 3 Lenovo IdeaTab A2109 System Board Replacement: stap 7, afbeelding 3 van 3
    • Use tweezers to flip up the small black plastic locks on all four connections.
    • Carefully remove each of the exposed ribbons.
  8. Lenovo IdeaTab A2109 System Board Replacement: stap 8, afbeelding 1 van 2 Lenovo IdeaTab A2109 System Board Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
  9. Lenovo IdeaTab A2109 System Board Replacement: stap 9, afbeelding 1 van 2 Lenovo IdeaTab A2109 System Board Replacement: stap 9, afbeelding 2 van 2
    • Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
  10. Lenovo IdeaTab A2109 System Board Replacement: stap 10, afbeelding 1 van 3 Lenovo IdeaTab A2109 System Board Replacement: stap 10, afbeelding 2 van 3 Lenovo IdeaTab A2109 System Board Replacement: stap 10, afbeelding 3 van 3
    • Disconnect the HDMI connection with the system board
    • Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
    • Slide out the system board from its housing tab on the upper right corner.
    • Pull the board slowly away from the tab, and it will pop out.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kyle
581 Reputatie
2 handleidingen geschreven
Cal Poly, Team 7-19, Regan Spring 2014 Lid van Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,583
