Inleiding
Use this guide to replace the speakers.
Onderdelen
Geen onderdelen nodig.
Look at the back of the tablet and locate the speakers on top of the rear cover.
There is a smaller indentation in the plastic cover that runs across the top of the device.
Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
Pry open cover using a plastic opening tool.
Leave plastic opening tool in place to maintain the separation.
It may take a little force to separate from the front face of the device
Slide the plastic opening tool to one corner.
Place another plastic opening tool into the gap and slide it to the opposite corner.
Pull the rear cover up and back to separate it from front face of the device.
Remove the following five screws:
Two M 3.0 x 3.0 mm #00 phillips screws (black)
Three M 5.3 x 1.75 mm #00 phillips screws (silver)
Disconnect the HDMI connection with the system board
Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free
Slide out the system board from its housing tab on the upper right corner
Pull the board slowly away from the tab, and it will pop out.
Remove the following two screws:
Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
Then, slide newly exposed ribbons out.
