Ga door naar hoofdinhoud
Lenovo IdeaTab A2109 Digital Board Replacement
Wat je nodig hebt
  1. Lenovo IdeaTab A2109 Digital Board Replacement, Digital Board: stap 1, afbeelding 1 van 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller plastic cover that runs across the top of the device.
    • Wedge the blue opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Digital Board Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaTab A2109 Digital Board Replacement: stap 2, afbeelding 2 van 2
    • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Lenovo IdeaTab A2109 Digital Board Replacement: stap 3, afbeelding 1 van 3 Lenovo IdeaTab A2109 Digital Board Replacement: stap 3, afbeelding 2 van 3 Lenovo IdeaTab A2109 Digital Board Replacement: stap 3, afbeelding 3 van 3
    • Once it is unscrewed, remove the rear cover
    • This may take a little force to get off but with enough force it should pop right off
    • Use a blue opening tool to pry it open
    • Slide the tool to one corner then grab another tool and slide it to the opposite corner
    • Pull the cover up and it will come off
  4. Lenovo IdeaTab A2109 Digital Board Replacement: stap 4, afbeelding 1 van 2 Lenovo IdeaTab A2109 Digital Board Replacement: stap 4, afbeelding 2 van 2
    • Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
    • Then, slide newly exposed ribbons out.
  5. Lenovo IdeaTab A2109 Digital Board Replacement: stap 5, afbeelding 1 van 2 Lenovo IdeaTab A2109 Digital Board Replacement: stap 5, afbeelding 2 van 2
    • M5.3 x 1.75 mm #00 phillips screws (silver)
  6. Lenovo IdeaTab A2109 Digital Board Replacement: stap 6, afbeelding 1 van 1
    • Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Brian
565 Reputatie
2 handleidingen geschreven
Cal Poly, Team 7-19, Regan Spring 2014 Lid van Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 3,056
