Ga door naar hoofdinhoud
Lenovo IdeaTab A2109 Camera Assembly Replacement
Wat je nodig hebt
  1. Lenovo IdeaTab A2109 Camera Assembly Replacement, Camera Assembly: stap 1, afbeelding 1 van 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • Locate the small indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool in this indentation, under the middle of the cover as shown.
    • Pry up and push to remove the cover.
  2. Lenovo IdeaTab A2109 Camera Assembly Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaTab A2109 Camera Assembly Replacement: stap 2, afbeelding 2 van 2
    • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Lenovo IdeaTab A2109 Camera Assembly Replacement: stap 3, afbeelding 1 van 3 Lenovo IdeaTab A2109 Camera Assembly Replacement: stap 3, afbeelding 2 van 3 Lenovo IdeaTab A2109 Camera Assembly Replacement: stap 3, afbeelding 3 van 3
    • Pry open the front and rear faces using a plastic opening tool.
    • It may take a little force to separate the front and rear faces of the device.
    • Slide the plastic opening tool to one corner.
    • Place another plastic opening tool into the gap and slide it to the opposite corner as shown.
    • Pull the rear cover up and back to separate it from front face of the device.
  4. Lenovo IdeaTab A2109 Camera Assembly Replacement: stap 4, afbeelding 1 van 1
    • Slide the rear camera ribbon from the system board.
    • Pull up on the black plastic lock on the system board for the front camera and slide the ribbon out.
    • Now, you are ready to remove the front and rear facing cameras.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Abigail Bertholf
521 Reputatie
1 Handleiding geschreven
Cal Poly, Team 7-19, Regan Spring 2014 Lid van Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 31
Altijd: 840
