Ga door naar hoofdinhoud
Lenovo IdeaTab A2109 Battery Replacement
Wat je nodig hebt
  1. Lenovo IdeaTab A2109 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaTab A2109 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 Battery Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaTab A2109 Battery Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 Battery Replacement: stap 4, afbeelding 1 van 2 Lenovo IdeaTab A2109 Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 Battery Replacement: stap 5, afbeelding 1 van 2 Lenovo IdeaTab A2109 Battery Replacement: stap 5, afbeelding 2 van 2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Kyle
581 Reputatie
2 handleidingen geschreven
Cal Poly, Team 7-19, Regan Spring 2014 Lid van Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Leden
15 handleidingen geschreven
Één opmerking
If there is an SD Micro memory card installed, REMOVE IT!, before the back cover. Otherwise, the card reader/writer will be damaged.
FilAm Harley - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 8,302
