Ga door naar hoofdinhoud
Lenovo IdeaPad Z570 Screen Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Z570 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Screen Replacement: stap 2, afbeelding 1 van 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Screen Replacement: stap 3, afbeelding 1 van 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Screen Replacement: stap 4, afbeelding 1 van 2 Lenovo IdeaPad Z570 Screen Replacement: stap 4, afbeelding 2 van 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Screen Replacement, Screen: stap 5, afbeelding 1 van 1
    • Open up the laptop with the screen facing you.
  6. Lenovo IdeaPad Z570 Screen Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaPad Z570 Screen Replacement: stap 6, afbeelding 2 van 2
    • Remove the two rubber square screw covers located in the left and right lower hand corners of the screen.
  7. Lenovo IdeaPad Z570 Screen Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaPad Z570 Screen Replacement: stap 7, afbeelding 2 van 2
    • Unscrew the two 4 mm screws behind the two rubber screw covers using the Phillips #0 screwdriver.
  8. Lenovo IdeaPad Z570 Screen Replacement: stap 8, afbeelding 1 van 2 Lenovo IdeaPad Z570 Screen Replacement: stap 8, afbeelding 2 van 2
    • Using the opening tool, pry open the plastic screen border, beginning with the upper right hand corner then working your way around.
    • Pry off the screen cover from the device.
  9. Lenovo IdeaPad Z570 Screen Replacement: stap 9, afbeelding 1 van 2 Lenovo IdeaPad Z570 Screen Replacement: stap 9, afbeelding 2 van 2
    • Remove the two 2 mm screws at the top two corners of the screen using the Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Screen Replacement: stap 10, afbeelding 1 van 2 Lenovo IdeaPad Z570 Screen Replacement: stap 10, afbeelding 2 van 2
    • Loosen the four 2 mm screws located at the bottom corners of the screen.
    • These screws cannot be removed.
  11. Lenovo IdeaPad Z570 Screen Replacement: stap 11, afbeelding 1 van 3 Lenovo IdeaPad Z570 Screen Replacement: stap 11, afbeelding 2 van 3 Lenovo IdeaPad Z570 Screen Replacement: stap 11, afbeelding 3 van 3
    • Tilt the screen forward gently.
    • Remove four 3 mm screws on the sides of the brackets holding the screen (two on the left side and two on the right side) using the Phillips #0 screwdriver.
  12. Lenovo IdeaPad Z570 Screen Replacement: stap 12, afbeelding 1 van 1
    • Lean the LCD screen face-down on the keyboard gently.
  13. Lenovo IdeaPad Z570 Screen Replacement: stap 13, afbeelding 1 van 3 Lenovo IdeaPad Z570 Screen Replacement: stap 13, afbeelding 2 van 3 Lenovo IdeaPad Z570 Screen Replacement: stap 13, afbeelding 3 van 3
    • Gently remove the adhesive covering surrounding the wires that’s connected to the back of the screen.
    • Disconnect the plug from the connection terminal.
    • Remove the screen completely.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Daniel Lopes
610 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 Lid van UMass Dartmouth, Team S1-G6, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G6
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 1,037
