Ga door naar hoofdinhoud
Lenovo IdeaPad Z570 Keyboard Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Z570 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Keyboard Replacement: stap 4, afbeelding 1 van 2 Lenovo IdeaPad Z570 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Keyboard Replacement, Disc Drive: stap 5, afbeelding 1 van 1
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Keyboard Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaPad Z570 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Keyboard Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaPad Z570 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Keyboard Replacement: stap 8, afbeelding 1 van 2 Lenovo IdeaPad Z570 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Gently remove the disc drive from the left hand side of the laptop.
  9. Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: stap 9, afbeelding 1 van 3 Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: stap 9, afbeelding 2 van 3 Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: stap 9, afbeelding 3 van 3
    • Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Orient the laptop at a 90 degree angle with the keyboard being vertical and the screen horizontal to the surface you are working on.
  11. Lenovo IdeaPad Z570 Keyboard Replacement: stap 11, afbeelding 1 van 2 Lenovo IdeaPad Z570 Keyboard Replacement: stap 11, afbeelding 2 van 2
    • Pry the keyboard off staring from the corner where the “esc”” key is located using an opening tool.
    • Now orient the laptop in the standard position and take off the keyboard.
  12. Lenovo IdeaPad Z570 Keyboard Replacement: stap 12, afbeelding 1 van 3 Lenovo IdeaPad Z570 Keyboard Replacement: stap 12, afbeelding 2 van 3 Lenovo IdeaPad Z570 Keyboard Replacement: stap 12, afbeelding 3 van 3
    • At the terminal block, flip the black switch on the terminal up.
  13. Lenovo IdeaPad Z570 Keyboard Replacement: stap 13, afbeelding 1 van 2 Lenovo IdeaPad Z570 Keyboard Replacement: stap 13, afbeelding 2 van 2
    • Pull the keyboard out from the terminal block.
Conclusie
Mya DeSantos
318 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 Lid van UMass Dartmouth, Team S1-G6, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G6
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 1,140
