Ga door naar hoofdinhoud
Lenovo IdeaPad Yoga 11S Top Assembly Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: stap 1, afbeelding 1 van 3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: stap 1, afbeelding 2 van 3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: stap 1, afbeelding 3 van 3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Remove Keyboard: stap 2, afbeelding 1 van 1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S Top Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S Top Assembly Replacement: stap 4, afbeelding 1 van 3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement: stap 4, afbeelding 2 van 3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement: stap 4, afbeelding 3 van 3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
Conclusie
Landon Epps
982 Reputatie
5 handleidingen geschreven
Baylor, Team 7-11, Williams Spring 2015 Lid van Baylor, Team 7-11, Williams Spring 2015
BU-WILLIAMS-S15S7G11
3 Leden
10 handleidingen geschreven
Één opmerking
I am looking into buying one of these but looking at your pictures I can't find the SSD. Is it user upgradeable?
ggr - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 3,126
