Ga door naar hoofdinhoud
Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement, Heat Sink: stap 1, afbeelding 1 van 1
    • Flip the Lenova ideapad onto its back and remove the screws using a screwdriver with a PH0 bit. All screws will use this bit.
    • 8 (5.35mm long screws)
    • 2 (15.37mm long screws)
    • 1 (5.63mm long screw)
  2. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement: stap 2, afbeelding 2 van 2
    • Firmly pull the cover off and locate the screws circled in red. These screws will stay attached to the old heat sink.
    • Loosen each screw until an audible click can be heard. The screws do not need to be fully removed from the old heat sink.
  3. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement: stap 3, afbeelding 1 van 1
    • Carefully grab the heat sink and lift it straight up. This is to prevent spreading thermal paste.
  4. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement: stap 4, afbeelding 1 van 1
Conclusie
With all steps completed test the Lenova Ideapad to ensure it is properly working. It is recommended to run intensive applications while monitoring internal temperatures. This will show if the cooling system is properly working.
Blake Ludge
109 Reputatie
1 Handleiding geschreven
IUPUI, Team 3-1, Harley Spring 2023 Lid van IUPUI, Team 3-1, Harley Spring 2023
IUPUI-HARLEY-S23S3G1
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 221
