Ga door naar hoofdinhoud
Lenovo IdeaPad Y510P Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Y510P Hard Drive Replacement, Remove the Battrty: stap 1, afbeelding 1 van 1
    • Locate the two battery locks on the bottom of the computer.
    • Slide the left battery lock to the left, exposing the red indicator.
    • While holding the right battery lock to the right, gently pull the battery out.
    • Fully discharge the laptop by pressing and holding the power button for 10 seconds after removing the battery. This ensures that there is no electricity in the laptop itself.
  2. Lenovo IdeaPad Y510P Hard Drive Replacement, Remove the back Panel: stap 2, afbeelding 1 van 2 Lenovo IdeaPad Y510P Hard Drive Replacement, Remove the back Panel: stap 2, afbeelding 2 van 2
    • Unscrew all nine of the backplate screws with a JI head screwdriver.
    • Carefully pry the backplate off of the laptop.
    • If there is resistance, check for any remaining screws.
  3. Lenovo IdeaPad Y510P Hard Drive Replacement, Remove the Old hard Drive: stap 3, afbeelding 1 van 1
    • Gently lift and remove the hard drive.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 46
Altijd: 2,997
