Ga door naar hoofdinhoud
Lenovo IdeaPad Y510P Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Y510P Hard Drive Replacement, Remove the Battrty: stap 1, afbeelding 1 van 1
    • Turning over the laptop, look for two tabs that are located by the fan
    • Push these tabs to the opposite sides (left to right and vise versa.) when done correctly, you should see at least one tab with a red indicator on the right
    • Carefully remove the battery by slowly pulling the battery towards you, the battery should come out with no force
    • Fully discharge the laptop by pressing and holding the power button for 10 seconds after removing the battery. This ensures that there is no electricity in the laptop itself
  2. Lenovo IdeaPad Y510P Hard Drive Replacement, Remove the back Panel: stap 2, afbeelding 1 van 2 Lenovo IdeaPad Y510P Hard Drive Replacement, Remove the back Panel: stap 2, afbeelding 2 van 2
    • Take a JI head screwdriver and remove the nine screws holding the back panel down.
    • When done correctly, the back panel should come off with little to no difficulty. If there is resistance, make sure that all screws are removed
  3. Lenovo IdeaPad Y510P Hard Drive Replacement, Remove the Old hard Drive: stap 3, afbeelding 1 van 1
    • Gently lift and remove the hard drive.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 48
Altijd: 2,410
