Inleiding
This guide will help you take off your front casing in order to access your touchpad.
Wat je nodig hebt
Slide the lock on the right side until you hear a click. Once you hear a click , you should see the color red.
Unlock the battery latch by pulling it up.
It should reveal red underneath when it's unlocked.
Remove a total of 8 screws.
Red circles are m2.5 x 10 mm flathead screws.
Orange circles m2 x 3mm flathead screws.
Yellow circle is m2.5 x 4mm flathead screw.
