Inleiding
This guide is to be used to remove your motherboard from your IdeaPad Y500.
Wat je nodig hebt
Slide the lock on the right side until you hear a click. Once you hear a click , you should see the color red.
Unlock the battery latch by pulling it up.
It should reveal red underneath when it's unlocked.
Remove a total of 8 screws.
Red circles are m2.5 x 10 mm flathead screws.
Orange circles m2 x 3mm flathead screws.
Yellow circle is m2.5 x 4mm flathead screw.
Peel up the black tab and remove the tape completely.
Remove the cable revealed underneath while pulling up the tape.
3 andere personen hebben deze handleiding voltooid.
