Ga door naar hoofdinhoud
Lenovo IdeaPad Y410p Screen Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Y410p Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Screen Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad Y410p Screen Replacement: stap 2, afbeelding 2 van 2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Screen Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad Y410p Screen Replacement: stap 3, afbeelding 2 van 2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Screen Replacement, Screen: stap 4, afbeelding 1 van 2 Lenovo IdeaPad Y410p Screen Replacement, Screen: stap 4, afbeelding 2 van 2
    • Using the metal spudger, pry the screen cover off from all sides.
    • Carefully lift the screen cover up and outwards.
    • Place the screen cover aside.
  5. Lenovo IdeaPad Y410p Screen Replacement: stap 5, afbeelding 1 van 3 Lenovo IdeaPad Y410p Screen Replacement: stap 5, afbeelding 2 van 3 Lenovo IdeaPad Y410p Screen Replacement: stap 5, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, remove the four 8mm screws from each corner of the screen.
    • Carefully lift the screen up and place it face down on the keyboard.
    • A thick cord connects the bottom of the screen to the computer. Do not tug or remove this cord from the computer.
  6. Lenovo IdeaPad Y410p Screen Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaPad Y410p Screen Replacement: stap 6, afbeelding 2 van 2
    • Remove the adhesive tape from the small rectangular connector at the bottom of the screen.
    • Carefully pull the wire connector from the screen connector.
    • Remove the screen.
Conclusie
Nick Torres
580 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 335
