Ga door naar hoofdinhoud
Lenovo IdeaPad Y410p Keyboard Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Y410p Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Keyboard Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad Y410p Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Keyboard Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad Y410p Keyboard Replacement: stap 3, afbeelding 2 van 2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 2 Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Power off your laptop.
    • Use a metal spudger to loosen the frame of the keyboard by running it under the edges of the keyboard as shown.
    • After loosening the keyboard frame, you should be able to gently lift up the keyboard.
  5. Lenovo IdeaPad Y410p Keyboard Replacement: stap 5, afbeelding 1 van 3 Lenovo IdeaPad Y410p Keyboard Replacement: stap 5, afbeelding 2 van 3 Lenovo IdeaPad Y410p Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Be careful when lifting the keyboard so that you do not damage the ribbon cable connector.
    • Detach the ribbon cables from the latches shown.
Conclusie
Nick Torres
580 Reputatie
5 handleidingen geschreven
2Gids Commentaar
Terrible guide - completely fails to point out the two screws that hold the keyboard down underneath the bottom casing. Bent my keyboard thanks to this.
Dragon - Antwoord
Awful guide. Wish I'd seen the other comment before I also ruined my keyboard. Thought it popped out, but there's 2 screws under the bottom case that hold it (remove!) … bent the keyboard frame and ripped the screw tabs off. Was just trying to clean it. Now it needs total replacement.
How is this article reportable?
Nateb - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 32
Altijd: 1,068
