Ga door naar hoofdinhoud
Inleiding
The Lenovo IdeaPad Y410P uses a standard laptop hard drive, so it is simple to replace. Hard drives are often easily accessed, and this one is no different. This hard drive can be replaced in just 2 simple steps.
Onderdelen
Geen onderdelen opgegeven.
  1. Turn off your laptop before starting.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Slide the left battery lock to the unlock position and release. Slide the right battery lock to the unlock positon and hold it in place.
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  4. While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside. While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  5. Using the Phillips #0 screwdriver, remove the eight 8mm screws that fasten the bottom cover. Lift bottom cover off using a metal spudger and set it  aside. Lift bottom cover off using a metal spudger and set it  aside.
    • Using the Phillips #0 screwdriver, remove the eight 8mm screws that fasten the bottom cover.
    • Lift bottom cover off using a metal spudger and set it aside.
  6. If you intend to reuse this hard drive, be careful removing it as hard impacts may damage the device. Using the Phillips #0 screwdriver, remove the two 3mm screws at the end of the hard drive bracket. Slide the hard drive out of its seat.
    • If you intend to reuse this hard drive, be careful removing it as hard impacts may damage the device.
    • Using the Phillips #0 screwdriver, remove the two 3mm screws at the end of the hard drive bracket.
    • Slide the hard drive out of its seat.
Conclusie
Nick Torres
559 Reputatie
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 3
Altijd: 82
