Ga door naar hoofdinhoud
Lenovo IdeaPad U530 Touch Fan Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad U530 Touch Fan Replacement, Battery: stap 1, afbeelding 1 van 3 Lenovo IdeaPad U530 Touch Fan Replacement, Battery: stap 1, afbeelding 2 van 3 Lenovo IdeaPad U530 Touch Fan Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the back panel by removing all screws. Use a PH000 screwdriver head.
    • Make sure to also remove the hinge screws.
  2. Lenovo IdeaPad U530 Touch Fan Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad U530 Touch Fan Replacement: stap 2, afbeelding 2 van 2
    • To remove the panel, use a plastic opening tool to prevent any damage.
  3. Lenovo IdeaPad U530 Touch Fan Replacement: stap 3, afbeelding 1 van 1
    • Locate and assess the battery. Pictured in the upper right area of the computer.
  4. Lenovo IdeaPad U530 Touch Fan Replacement: stap 4, afbeelding 1 van 2 Lenovo IdeaPad U530 Touch Fan Replacement: stap 4, afbeelding 2 van 2
    • Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
    • Be careful to keep track of all removed screws.
  5. Lenovo IdeaPad U530 Touch Fan Replacement: stap 5, afbeelding 1 van 1
    • Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
    • To remove the connection, please pull firmly, as it well secured.
  6. Lenovo IdeaPad U530 Touch Fan Replacement: stap 6, afbeelding 1 van 1
    • Simply lift the battery out of the computer, and acquire a replacement.
  7. Lenovo IdeaPad U530 Touch Fan Replacement, Fan: stap 7, afbeelding 1 van 3 Lenovo IdeaPad U530 Touch Fan Replacement, Fan: stap 7, afbeelding 2 van 3 Lenovo IdeaPad U530 Touch Fan Replacement, Fan: stap 7, afbeelding 3 van 3
    • Remove the six 3 mm screws from the fan using a JIS #1 screwdriver.
  8. Lenovo IdeaPad U530 Touch Fan Replacement: stap 8, afbeelding 1 van 2 Lenovo IdeaPad U530 Touch Fan Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the connecter cords from the fan and remove the fan.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 242
