Ga door naar hoofdinhoud
Lenovo IdeaPad U430 Touch Wifi Card Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad U430 Touch Wifi Card Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Wifi Card Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad U430 Touch Wifi Card Replacement: stap 3, afbeelding 2 van 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Wifi Card Replacement, Wifi Card: stap 4, afbeelding 1 van 1
    • Remove the two 2.8mm screws using the Phillips #0 screwdriver.
  4. Lenovo IdeaPad U430 Touch Wifi Card Replacement: stap 5, afbeelding 1 van 2 Lenovo IdeaPad U430 Touch Wifi Card Replacement: stap 5, afbeelding 2 van 2
    • Remove the two snap cables connecting the wifi card to the rest of the computer.
  5. Lenovo IdeaPad U430 Touch Wifi Card Replacement: stap 6, afbeelding 1 van 1
    • Slide the Wifi card away from the Wifi card connector.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 606
