Inleiding
This guide will walk you through the process of replacing an unresponsive or broken trackpad for the Lenovo IdeaPad U430 Touch.
Wat je nodig hebt
Power off your computer before you begin.
Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
Remove the five 2.8 mm #1 Phillips head screws that hold down the battery pack.
Using a combination of plastic opening tool and spudger, press in on the clips on the sides of the battery connector and push the connector out
When you get the connector out far enough, grab behind the connector tabs with tweezers and wiggle the connector the rest of the way out.
Remove the two 2.8 mm screws attached to the trackpad using the Phillips #1 screwdriver.
Detach the zif ribbon labeled "TP" and "MB" at the "MB" end.
