Ga door naar hoofdinhoud
Lenovo IdeaPad U430 Touch Bottom Cover Removal
Wat je nodig hebt
  1. Lenovo IdeaPad U430 Touch Bottom Cover Removal, Bottom Cover: stap 1, afbeelding 1 van 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Bottom Cover Removal: stap 3, afbeelding 1 van 2 Lenovo IdeaPad U430 Touch Bottom Cover Removal: stap 3, afbeelding 2 van 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
Conclusie
Patrick Ripkey
627 Reputatie
5 handleidingen geschreven
USF Tampa, Team S2-G6, Nance Spring 2017 Lid van USF Tampa, Team S2-G6, Nance Spring 2017
USFT-NANCE-S17S2G6
3 Leden
15 handleidingen geschreven
Één opmerking
When removing the cover, be careful: There are a few (two or three?) plastic hooks that break easily in the area around the ports and the SD slot. (It's no big deal if they do break, but you can avoid it.)
Tom Janson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 2,957
