Ga door naar hoofdinhoud
Onderdelen
  1. Using the metal spudger, remove all the rubber squares on the bottom of the laptop. Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Remove the three 6 mm Phillips #1 screws  holding the panel on the laptop. Pry the panel from the laptop using your hands or the metal spudger if necessary. Pry the panel from the laptop using your hands or the metal spudger if necessary.
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Nu winkelen
    iPhone X Fix Kits
    Nu winkelen
  4. Make sure your computer is turned off.
    • Make sure your computer is turned off.
    • Lift the back panel away from you.
    • Locate the battery in the bottom right corner.
  5. Remove the three 3mm screws located on the perimeter of the battery using the Phillips #1 screwdriver.
    • Remove the three 3mm screws located on the perimeter of the battery using the Phillips #1 screwdriver.
  6. Locate the small rectangle shaped connector to the left  of your battery. Use your fingers to gently detach the white connector. Use your fingers to gently detach the white connector.
    • Locate the small rectangle shaped connector to the left of your battery.
    • Use your fingers to gently detach the white connector.
Conclusie
Alysia Mcafee
107 Reputatie
1 Handleiding geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 5
Altijd: 152
