Inleiding
If your computer shuts down without warning after prolonged use or during computationally intensive tasks, then the thermal paste may need to be replaced. The thermal paste is a thermally conductive paste that goes between the heat sink and the CPU. It transfers heat from the CPU to the heat sink, so that it can be expelled by the fan.
Wat je nodig hebt
Unscrew the three screws on the bottom of the laptop that have small keyboard logos next to them using a PH1 screwdriver. These screws are 5.8mm long.
Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
Unscrew the nine screws that are around the edge of the laptop using a PH00 screwdriver. These screws are 5.7mm long.
Unscrew the remaining two M2.5X3 screws that were under the battery using a PH1 screwdriver. These screws are 3.7mm long.
Unscrew the three M2X3 screws that were under the hard drive using a PH1 screwdriver. These screws are 3.7mm long.
Carefully pull the glued plastic tab on the display connector away from the motherboard.
Pull the display cable itself out of the connector.
