Ga door naar hoofdinhoud
Lenovo IdeaPad U310 Ram Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad U310 Ram  Replacement, RAM: stap 1, afbeelding 1 van 1
    • Make sure device is turned off and disconnected from any power source before proceeding.
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Ram  Replacement: stap 2, afbeelding 1 van 1
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Ram  Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad U310 Ram  Replacement: stap 3, afbeelding 2 van 2
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Ram  Replacement: stap 4, afbeelding 1 van 1
    • Pry the RAM's two holding clips in an outward motion.
  5. Lenovo IdeaPad U310 Ram  Replacement: stap 5, afbeelding 1 van 2 Lenovo IdeaPad U310 Ram  Replacement: stap 5, afbeelding 2 van 2
    • Continue to pry open the clips, and slip the RAM from its housing.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 21
Altijd: 2,615
