Ga door naar hoofdinhoud
Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: stap 2, afbeelding 2 van 2
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Back Panel: stap 3, afbeelding 1 van 2 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Back Panel: stap 3, afbeelding 2 van 2
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: stap 4, afbeelding 1 van 1
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: stap 5, afbeelding 1 van 3 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: stap 5, afbeelding 2 van 3 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: stap 5, afbeelding 3 van 3
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Wi-Fi Network Card: stap 6, afbeelding 1 van 2 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Wi-Fi Network Card: stap 6, afbeelding 2 van 2
    • Remove both antenna wires by pulling upwards gently.
  7. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: stap 7, afbeelding 1 van 1
    • Using the #00 Phillips screwdriver, remove one 3mm screw from the network card.
  8. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: stap 8, afbeelding 1 van 2 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: stap 8, afbeelding 2 van 2
    • Slide Wi-Fi network card away from motherboard and remove gently.
Conclusie
Zack Colman
885 Reputatie
8 handleidingen geschreven
2 opmerkingen
Can I swap out the card with another make/model? If I don’t want to use a dongle and my OS doesn’t support the original one.
How do I know which will fit?
neb🇳🇴 - Antwoord
Many months later:
I replaced the card and booted up. No BIOS, just straight to error message:
"Unauthorized Wireless network card is plugged in. Power off and remove it."
Very sly move, Lenovo!
Now I need special hard- and software tools to modify UEFI!
neb🇳🇴 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 325
