Inleiding
This guide will explain how to replace your System Memory (also known as RAM). Faulty RAM modules may cause reduced system stability and performance.
Wat je nodig hebt
Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
Release the RAM from the motherboard by pressing the two locking latches away from each other.
Bijna klaar!
Conclusie
