Inleiding
Replacing your speakers may be necessary if they are producing scratchy audio or none at all.
Wat je nodig hebt
Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
Using a #0 Phillips screwdriver, remove the four 4mm screws that secure the hard drive bracket to the motherboard.
If any tape is present, remove all tape from the area within the red area.
Remove four cables connected to motherboard by pulling gently on connector at base of cables.
Using a #00 Phillips screwdriver, remove four 1mm screws from the two speakers.
