Ga door naar hoofdinhoud
Lenovo IdeaPad S210 Touch Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Hard Drive Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad S210 Touch Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Back Panel: stap 3, afbeelding 1 van 2 Lenovo IdeaPad S210 Touch Hard Drive Replacement, Back Panel: stap 3, afbeelding 2 van 2
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Hard Drive Replacement: stap 5, afbeelding 1 van 3 Lenovo IdeaPad S210 Touch Hard Drive Replacement: stap 5, afbeelding 2 van 3 Lenovo IdeaPad S210 Touch Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Hard Drive: stap 6, afbeelding 1 van 2 Lenovo IdeaPad S210 Touch Hard Drive Replacement, Hard Drive: stap 6, afbeelding 2 van 2
    • Using a #0 Phillips screwdriver, remove the four 4mm screws that secure the hard drive bracket to the motherboard.
  7. Lenovo IdeaPad S210 Touch Hard Drive Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaPad S210 Touch Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Slide your hard drive away from your motherboard until fully removed.
    • Be careful not to snag any wires routed along the battery side of the hard drive.
  8. Lenovo IdeaPad S210 Touch Hard Drive Replacement: stap 8, afbeelding 1 van 3 Lenovo IdeaPad S210 Touch Hard Drive Replacement: stap 8, afbeelding 2 van 3 Lenovo IdeaPad S210 Touch Hard Drive Replacement: stap 8, afbeelding 3 van 3
    • This step is only necessary if you are swapping your old hard drive for a new one.
    • Using a Phillips #0 screwdriver, remove four 2.5mm screws, two per side, to release the hard drive from its mounting bracket. These screws are directly next to each mounting screw you removed previously.
    • Install the mounting brackets onto the new hard drive during reassembly.
Conclusie
Zack Colman
885 Reputatie
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 11
Altijd: 1,394
