Inleiding
This guide will provide instructions to remove the bottom case of the laptop. This is the first step in replacing most of the parts in this computer.
Onderdelen
Geen onderdelen nodig.
  1. Turn off laptop before beginning.
    • Turn off laptop before beginning.
    • Remove the five 5.0 mm Phillips #0 screws marked in this picture.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Use the spudger to separate the bottom panel from the laptop case. It is recommended that you start from a corner and work your way around the panel. Be careful not to bend or break the bottom panel.
    • Use the spudger to separate the bottom panel from the laptop case.
    • It is recommended that you start from a corner and work your way around the panel.
    • Be careful not to bend or break the bottom panel.
  4. Lift up the right side of the case as shown, and slide it to the left to detach the case. The disk drive will remain attached to the bottom panel. Sliding the panel to the left disconnects it. To avoid damaging the disk drive connector, avoid lifting the right side of the panel too far up.
    • Lift up the right side of the case as shown, and slide it to the left to detach the case.
    • The disk drive will remain attached to the bottom panel. Sliding the panel to the left disconnects it.
    • To avoid damaging the disk drive connector, avoid lifting the right side of the panel too far up.
Conclusie
Één commentaar
awful guide, you need to remove the screws underneath the pads on the bottom plate, as well as remove the screws underneath the keyboard that lets you take the disc drive out, then take out the disc drive revealing more screws needed to take out in order to take off the bottom plate.
Ward McKinley - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 8
Altijd: 89
