Ga door naar hoofdinhoud
Lenovo IdeaPad N586 Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad N586 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Lenovo IdeaPad N586 Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad N586 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Hard Drive Replacement, Back Panel: stap 3, afbeelding 1 van 1
    • Remove the two screws highlighted.
  4. Lenovo IdeaPad N586 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • This is the back of the laptop with the cover removed.
  5. Lenovo IdeaPad N586 Hard Drive Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • Now remove the last two screws highlighted
  6. Lenovo IdeaPad N586 Hard Drive Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaPad N586 Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Push hard drive away from the center of the chassis.
    • Lift the hard drive out of the chassis using the tab located on the drive.
Conclusie
Christopher
676 Reputatie
6 handleidingen geschreven
Cal Poly, Team 8-7, Regan Spring 2014 Lid van Cal Poly, Team 8-7, Regan Spring 2014
CPSU-REGAN-S14S8G7
5 Leden
10 handleidingen geschreven
Één opmerking
Please include that the back panel SLIDES out. I pried it out and broke off three of the retaining tabs. It easily slides out, and it would have been nice if that was in the directions. Most laptops panels are pried out.
stephenkingsley - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,139
