Inleiding
If the device is failing to boot, then the issue may lie with the motherboard. To replace this component, follow this guide.
Wat je nodig hebt
Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
Rotate the laptop so that now the hinge is facing away from you.
Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop.
Slide the bottom panel towards you until it stops, and then carefully lift it off.
Remove the five ribbon cables on the top of the computer.
Gently remove the single cable from its socket.
3 andere personen hebben deze handleiding voltooid.
