Ga door naar hoofdinhoud
Lenovo IdeaPad N580 CPU Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad N580 CPU Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
  2. Lenovo IdeaPad N580 CPU Replacement: stap 2, afbeelding 1 van 1
    • Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
  3. Lenovo IdeaPad N580 CPU Replacement: stap 3, afbeelding 1 van 1
    • Now take your left hand and slide the left switch to the left.
    • This switch will not click in place like the other switch, so make sure to keep your left hand on the switch.
  4. Lenovo IdeaPad N580 CPU Replacement: stap 4, afbeelding 1 van 1
    • Take your free hand and place it on the battery. Gently slide it away from its slot.
  5. Lenovo IdeaPad N580 CPU Replacement, Keyboard and Trackpad: stap 5, afbeelding 1 van 3 Lenovo IdeaPad N580 CPU Replacement, Keyboard and Trackpad: stap 5, afbeelding 2 van 3 Lenovo IdeaPad N580 CPU Replacement, Keyboard and Trackpad: stap 5, afbeelding 3 van 3
    • Rotate the laptop so that now the hinge is facing away from you.
    • Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop.
    • Slide the bottom panel towards you until it stops, and then carefully lift it off.
  6. Lenovo IdeaPad N580 CPU Replacement: stap 6, afbeelding 1 van 1
    • Remove the three 2.0 x 6.0 mm Phillips #0 screws located on the underside of the device.
  7. Lenovo IdeaPad N580 CPU Replacement: stap 7, afbeelding 1 van 3 Lenovo IdeaPad N580 CPU Replacement: stap 7, afbeelding 2 van 3 Lenovo IdeaPad N580 CPU Replacement: stap 7, afbeelding 3 van 3
    • Turn the laptop right side up and open the lid.
    • Using the spudger and your fingers, get in between the keyboard's edge and lift it up.
    • Carefully lift the keyboard ribbon cable out of the socket it is in.
  8. Lenovo IdeaPad N580 CPU Replacement: stap 8, afbeelding 1 van 2 Lenovo IdeaPad N580 CPU Replacement: stap 8, afbeelding 2 van 2
    • Remove the 2.5 x 6.0 mm Phillips #0 from the center of the device.
    • Close the laptop and place it face down once again.
  9. Lenovo IdeaPad N580 CPU Replacement: stap 9, afbeelding 1 van 1
    • If a hard disk drive is installed, remove the two 2.5 x 4.0 mm Phillips #0 screws.
    • Slide the hard disk drive out of its socket.
  10. Lenovo IdeaPad N580 CPU Replacement: stap 10, afbeelding 1 van 1
    • Remove the eleven 2.5 x 6.0 mm Phillips #0 screws.
    • Remove the three 2.0 x 3.0 mm flat head screws.
    • Remove the 2.5 x 4.0 mm Phillips #0 screw.
  11. Lenovo IdeaPad N580 CPU Replacement: stap 11, afbeelding 1 van 2 Lenovo IdeaPad N580 CPU Replacement: stap 11, afbeelding 2 van 2
    • Disconnect the two ribbon cables from the center.
    • Lift the keyboard bezel (with trackpad) straight up and out.
  12. Lenovo IdeaPad N580 CPU Replacement, Motherboard: stap 12, afbeelding 1 van 1
    • Remove the five ribbon cables on the top of the computer.
    • Gently remove the single cable from its socket.
  13. Lenovo IdeaPad N580 CPU Replacement: stap 13, afbeelding 1 van 1
    • Remove the three 2.5 x 3.0 mm Phillips #0 screws on the motherboard.
  14. Lenovo IdeaPad N580 CPU Replacement: stap 14, afbeelding 1 van 2 Lenovo IdeaPad N580 CPU Replacement: stap 14, afbeelding 2 van 2
    • Using your fingers or a spudger, lift the motherboard slightly.
    • Detach the single cable from underneath.
    • Lift the motherboard the rest of the way out.
  15. Lenovo IdeaPad N580 CPU Replacement, CPU: stap 15, afbeelding 1 van 1
    • Detach the cable next to the fan assembly.
  16. Lenovo IdeaPad N580 CPU Replacement: stap 16, afbeelding 1 van 2 Lenovo IdeaPad N580 CPU Replacement: stap 16, afbeelding 2 van 2
    • Remove the three 2.0 x 3.2 mm Phillips #0 screws from the fan.
    • Lift the fan straight off the motherboard.
  17. Lenovo IdeaPad N580 CPU Replacement: stap 17, afbeelding 1 van 2 Lenovo IdeaPad N580 CPU Replacement: stap 17, afbeelding 2 van 2
    • Using a flathead screwdriver, turn the beige lock to counterclockwise to unlocked.
  18. Lenovo IdeaPad N580 CPU Replacement: stap 18, afbeelding 1 van 1
    • Lift the CPU out of the socket.
    • Upon replacing the CPU and re-locking back in place, remember to apply thermal paste in order to prevent overheating.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Alex Amorim
907 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S5-G2, Peak Spring 2018 Lid van UMass Dartmouth, Team S5-G2, Peak Spring 2018
UMASSD-PEAK-S18S5G2
2 Leden
Één opmerking
süper olmuş eline sağlık çok açıklayıcı ve başarılı olmuş teşekkür ederim
Ümit Kocamanoglu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 15
Altijd: 1,096
