Inleiding
This is a guide to replace the faulty screen of the Lenovo IdeaPad G50-45 laptop.
The laptop screen is a component which displays graphics on a liquid crystal display (LCD) screen. Replacement is necessary if the screen becomes physically damaged such as having cracks, multi-colored vertical lines and black or white spots.
Before using this guide, troubleshoot the screen to make sure that physical damage is actually present- oftentimes image distortion and resolution lines can be caused by graphics card or processor failure too. Faulty video cable also causes these problems.
The replacement LCD panel must be compatible to your laptop specifications. This includes screen size, resolution, back-light and the connector type at the bottom of the screen. The exact screen model number can be checked at the backside of the original screen.
Handle the replacement screen with caution as it is fragile and easily damages if dropped or overly pressured. Make sure to power off your laptop completely and disconnect from any external power source prior to beginning this process.
Wat je nodig hebt
6 andere personen hebben deze handleiding voltooid.
