Ga door naar hoofdinhoud
Lenovo IdeaPad G50-45 DVD Drive Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad G50-45 DVD Drive Replacement, DVD Drive: stap 1, afbeelding 1 van 1
    • First, remove the three screws located on the bottom panel of the laptop using a Philips #2 screwdriver.
    • To avoid losing the small screws, put them in a container.
  2. Lenovo IdeaPad G50-45 DVD Drive Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad G50-45 DVD Drive Replacement: stap 2, afbeelding 2 van 2
    • To remove the panel on the laptop, gently slide the panel away from the battery.
    • Make sure to slide the panel away before you lift to keep the panel from breaking.
    • Lift up the panel and place it to the side.
  3. Lenovo IdeaPad G50-45 DVD Drive Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad G50-45 DVD Drive Replacement: stap 3, afbeelding 2 van 2
    • Remove the indicated screw holding the DVD Drive.
    • To avoid losing the screw, place it in the same container used to hold the other three screws.
  4. Lenovo IdeaPad G50-45 DVD Drive Replacement: stap 4, afbeelding 1 van 1
    • Push the now-free tab towards the DVD Drive using a flathead screwdriver.
    • Do not pry up the now-free tab.
  5. Lenovo IdeaPad G50-45 DVD Drive Replacement: stap 5, afbeelding 1 van 1
    • Lastly, pull out the DVD Drive; it should come out easily.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Saulo Gomes
601 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Lid van UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 8,478
