Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement, Base Cover: stap 1, afbeelding 1 van 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement, SSD Card: stap 3, afbeelding 1 van 1
    • Remove the single 3.5 mm screw that secures the SSD card using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: stap 4, afbeelding 1 van 2 Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers to gently pry up the protective cover off of the SSD card.
  5. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: stap 5, afbeelding 1 van 1
    • The SSD card will spring up to one side on its own.
  6. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: stap 6, afbeelding 2 van 2
    • Remove the SSD from the motherboard.
    • When reinstalling the SSD, push the SSD card back into its slot. The SSD card will click into place when it is secure and then rest at a 30 degree angle from the laptop.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 24
Altijd: 910
