Inleiding
This guide will show you how to replace the battery in your Lenovo IdeaPad Flex 6-14IKB. The battery is an essential part of the laptop because it is the energy storage device. The battery gives power to the laptop while it is not plugged into a charger. Your battery may need replacement if your laptop only powers on while plugged into a charger or it discharges very quickly when unplugged.
Before starting the replacement, make sure the laptop is fully turned off and unplugged from a power cord.
Wat je nodig hebt
Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
Remove the four 3.5 mm screws around the battery using a Phillips #00 screwdriver.
6 andere personen hebben deze handleiding voltooid.
