Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 5-1570 Heatsink Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Back Panel: stap 1, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 2, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 2, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 2, afbeelding 3 van 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 3, afbeelding 2 van 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Battery: stap 4, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Battery: stap 4, afbeelding 2 van 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 5, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 5, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 5, afbeelding 3 van 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Fan: stap 6, afbeelding 1 van 1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  7. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 7, afbeelding 1 van 1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  8. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 8, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  9. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Heatsink: stap 9, afbeelding 1 van 1
  10. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 10, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: stap 10, afbeelding 2 van 2
    • Carefully remove the heatsink from the device.
    • During reassembly, don't forget to apply thermal paste onto the heatsink. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
Conclusie
Don’t forget to reapply thermal paste during reassembly. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
Één andere persoon heeft deze handleiding voltooid.
Justin Ogihara
27.166 Reputatie
52 handleidingen geschreven
EDU Team Lid van EDU Team
Staff
7 Leden
637 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 768
