Inleiding
A faulty fan in the Lenovo IdeaPad Flex 5-1570 is a problem on its own but can also cause more serious problems for the device. Whether your fan is making noise, permanently damaged, or just simply won’t work, this guide will show you how to easily remove and replace it.
Wat je nodig hebt
Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
