Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 5-1470 Motherboard Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, SSD: stap 3, afbeelding 1 van 1
    • Remove the single 3.6 mm screw using a Phillips #00 screwdriver.
    • The SSD will pop up on its own after removing the screw.
  4. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: stap 4, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the three screws securing the fan.
    • Lift the fan up and out.
    • Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
    • Lift the hard drive up and out.
  5. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: stap 5, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
    • The Wi-Fi card will slightly lift away from the motherboard.
    • Pull the Wi-Fi card directly out of its port.
  6. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the three screws securing the motherboard.
    • Gently disconnect the cables and ribbon cables connected to the motherboard.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 28
Altijd: 407
