Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: stap 2, afbeelding 2 van 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement, Wifi Card: stap 3, afbeelding 1 van 1
    • Remove the foam on the WIFI card.
  4. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: stap 4, afbeelding 1 van 1
    • Remove the wires attached to the WIFI card.
  5. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the 4mm screw holding wifi card.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Elijah Ellis
616 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,871
