Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 4-1470 Touchpad Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: stap 2, afbeelding 2 van 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: stap 3, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: stap 3, afbeelding 2 van 2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: stap 4, afbeelding 1 van 1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery up and out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Touchpad: stap 6, afbeelding 1 van 1
    • Locate the touchpad.
  7. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: stap 7, afbeelding 2 van 2
    • Remove the three ribbon cables surrounding the touch pad.
  8. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: stap 8, afbeelding 1 van 1
    • Lift the base of the laptop from the screen and gently push the touchpad to remove.
Conclusie
Elijah Ellis
616 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G2
3 Leden
2 opmerkingen
do you know where to find this part? i have been looking everywhere haha.
Hanna Tafete - Antwoord
Can any body repair lenovo idea pad 1470. Touch screen ...tia
jgonzales - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,221
